Activity Forums Apple Final Cut Pro Legacy Is there a fix for Firewire DV captures with the wrong audio sample rate?
  • Is there a fix for Firewire DV captures with the wrong audio sample rate?
    Posted by Gareth Randall on July 27, 2007 at 6:51 am
    Whenever I make Firewire captures from my Panasonic consumer-level camcorder, the audio sample rate is always fractionally off 48K. It’ll be something like 48.0001 or 48.0003.
    This means that I always have to render the audio to 48.0000KHz once I’ve placed it into the timeline, which slows down editing. It’s an annoyance, because FCP is pretty quick to use otherwise.
    Are there any fixes for this issue beyond the rendering? FWIW, I *don’t* get the problem when capturing into Avid or Premiere Pro from the same camcorder. I’m using FCP 5.1.4 on a 2.16 MacBook Pro with 2Gb RAM running OS X 10.4.10.
    David Roth weiss replied 19 years, 1 month ago 2 Members · 1 Reply
  • David Roth weiss
    July 27, 2007 at 2:58 pm
    I’ve encountered that issue once or twice mayself. I either ignore it, or transcode the entire video file in QT Pro to a file with 48Khz audio.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
