Activity Forums Apple Final Cut Pro Legacy Is there a difference between 16×9 and 1.77:1 ?
  • Is there a difference between 16×9 and 1.77:1 ?
    Posted by Gary Gowman on July 2, 2008 at 6:35 pm
    I was asked to make two versions of a movie. One at 16×9 full frame and a 1.77 version. Is there a difference?
    Gary Gowman-Video Director
    Louisiana Media Services
    4K, 2K/DI, HDcamSR
    Assimilate Scratch and FCS2/Kona3 Suites
    Full Audio Production
    Jeremy Garchow replied 18 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    July 2, 2008 at 6:37 pm
    That’s the same aspect ratio.
    16 divided by 9 is 1.77 (sometimes rounded to 1.78)
  • Gary Gowman
    July 2, 2008 at 6:48 pm
    That’s what I thought. We were asked to make two versions (by a major film company). Must have been an intern filling in today. 🙂
    4K, 2K/DI, HDcamSR
  • Jeremy Garchow
    July 2, 2008 at 6:59 pm
    What’s the aspect of your source material?
    The reason I ask is because you can crop your image (if it’s bigger than 16×9) to 16×9 full frame. Then you can keep the aspect of your source material and letterbox it to 1.77:1
    Jeremy
  • Gary Gowman
    July 2, 2008 at 7:43 pm
    Not sure. I was only asked by my boss if there was a difference. I said they are the same and he replied that we were asked to make two deliverables as 16×9 full frame and another as 1.77. He will get back to the person asking for the two versions. 🙂
    4K, 2K/DI, HDcamSR
  • Jeremy Garchow
    July 2, 2008 at 7:54 pm
    Yeah, there’s a difference but it wholly depends on your source material. If it’s bigger than HD than this is where it will come in to play.
    Jeremy
  • Gary Gowman
    July 2, 2008 at 10:59 pm
    Project was shot with Sony F900 to HDcamSR deck as 422. We captured as HD 422 and edited, CC and so on. Nothing here about SD and letterbox, anamorphic. Just a request to deliver 16×9 full frame and another 1.77 both on HDcam tapes. Mee thinx thay konfuzed.
    4K, 2K/DI, HDcamSR
  • Jeremy Garchow
    July 2, 2008 at 11:27 pm
    [Gary Gowman] “Mee thinx thay konfuzed.”
    Well, no. 16×9 full frame would be your full HD frame (since you shot HD).
    But if you had a 2k frame, instead of cropping your frame to 16×9, you keep the 2k aspect ratio of the frame size and letterbox it to 1.77:1. Since you are in nothing but 16×9, you will probably only have to deliver 16×9. Hence they say 16×9 Full frame and then 1.77:1 (which would be a 16×9 letterbox within a frame of whatever your aspect ratio is that’s beyond 1080 HD).
    Make sense?
