Activity › Forums › Apple Final Cut Pro Legacy › Is there a depth of field plugin?
Posted by Ty Ford on August 26, 2009 at 9:02 pmThat simulates the reduced dof a film camera does?
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitarErik Lindahl replied 17 years, 1 month ago 7 Members · 6 Replies -
Steve Eisen
August 26, 2009 at 9:21 pmCheckout ShrinkRay at Crumplepop.com.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Dustin Parsons
August 26, 2009 at 9:28 pmAndy’s Region Blur might work as well – it’s free and I’ve found it very useful. The download button is the FCP effect window.
Mac Pro | Leopard 10.5.5
2.66GHz Dual-Core Intel Xeon | 4GB Ram
Final Cut Pro Studio 2 | Avid Media Composer -
Tom Matthies
August 27, 2009 at 2:18 amI believe that the new version might have that feature. You’d need to do it in layers, I’d imagine. I haven’t loaded my copy of Studio yet (waiting for Snow Leopard) but I’m pretty sure it;s in there. Otherwise Joe’s filters has a keyframable soft pattern filter that could work.
TomLife moves pretty fast. If you don’t stop and look around once in a while, you could miss it.–Ferris Bueller
Bob Pierce
August 27, 2009 at 1:49 pmTy,
Color has some nifty effects that allow you to blur part of the image. My experience is that it’s incredibly difficult to pull this off. It doesn’t really look like a lense’s shallow focus – It always looks like an effect. If you haven’t used Color yet, I highly recommend trying it out, it’s quite amazing. It is daunting at first though.
Good Luck!
Bob Piercehttp://www.lightstreamassociates.com
Mac Pro 2.66 – 8GB memory – Mac OS 10.5.5 – Quicktime 7.5.5 –
Mac Book Pro 2.33 Duo –
FC Studio 2 (Final Cut 6.0.4) – Kona Lhe
Adobe Production Suite CS3 –
Sony Multiformat 14″ – Panasonic 42″ Plasma –
Ikegami HLDV7 – PVW EX-1 -
David Bogie
August 27, 2009 at 6:36 pmDepth of field can be simulated using compound blur. The Crumblepop ShrinkRay filter is a prepackaged compound blur effect that dramatically simplifies the illusion. However, none of these are 3D aware and the illusion is easily destroyed by improper application of the filter’s blur ranges.
Motion 4 has a delightfully cool DOF function but it requires your guitar player to be a separate layer from the foreground and background elements.
bogiesan
Erik Lindahl
August 28, 2009 at 10:27 amLenscare by Frischluft is a terrific plugin. It however only works in After Effects. Depending on the effect you are trying to create it might not be a bad idea round-tripping into that application however.
https://www.frischluft.com/lenscare/index.php
Erik Lindahl
Freecloud Communication
