Activity Forums Adobe After Effects Is there a comp size limit in CS5.5?
  • Is there a comp size limit in CS5.5?
    Posted by Steven Escobar on September 12, 2011 at 1:18 am
    I was given a quicktime with animation with alpha that is over 11,000 pixels by 6800. I am putting it into a 1920×1080 comp and when I import it, I can see the the frame in the project window but when I drag and put it into my comp, all I see is black. If I go forward a couple of frames, sometimes I see the image but then it goes away and all I see is black again.
    Is there a comp size limit that after effects can preview and/or render? How can I use the quicktime and make it smaller in order to use it? Any suggestions?
    Steve
    Steven Escobar
    G4 1.25MHz Dual MDD
    1.25 RAM
    IgniterX RT w/component
    QT 6.04
    OS X.2.8
    FCP 4.1
    Med
    Ben G unguren replied 14 years, 11 months ago 5 Members · 6 Replies
  • Todd Kopriva
    September 12, 2011 at 1:49 am
    Searching for ‘composition size limit’ in After Effects Help brings up a page in After Effects Help that gives the maximum size for a composition.
    Are you scaling the huge image down to fit into your HD-sized composition? Or are you positioning it to show only a portion of the image in the relatively small composition frame?
    Do you really only have 1.25 GB of RAM? That is an incredibly small amount for After Effects, and is actually below the 2GB minimum system requirement.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Todd Kopriva
    September 12, 2011 at 1:51 am
    Also, your version of QuickTime doesn’t meet the minimum requirements for After Effects.
  • Brian Charles
    September 12, 2011 at 2:41 am
    Also : If you’re really on a G4 how on earth are you running CS5?
  • Steven Escobar
    September 12, 2011 at 2:47 am
    Okay guys. Just ignore my old computer settings. Using latest cs5.5 on intel computer with latest QuickTime etc. Does anyone have a suggestions?
    Steven Escobar
  • Eric Santiago
    September 12, 2011 at 3:52 am
    Ive heard numbers as high as 40k but I would get errors time to time with all kinds of sizes way lower than that.
  • Ben G unguren
    September 12, 2011 at 1:48 pm
    Sounds like a codec issue to me. I’d open the movie file in the old quicktime player, or MPEG Streamclip, or perhaps Photoshop, and export it as an image sequence, then work with that instead.
    For large files (filesize and framesize), image sequences are still king, IMO.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
