Activity Forums Adobe After Effects Is the trapcode horizon plugin best tools for camera mapping on panorama images?
  • Is the trapcode horizon plugin best tools for camera mapping on panorama images?
    Posted by Ali Khoshdouni on August 22, 2012 at 6:10 pm
    I was wathing some tutorial about camera move on images. thay was using trapcode horizon for that. but are there any other plugin for this work?
    Chip Simons replied 14 years ago 5 Members · 5 Replies
  • Tom Daigon
    August 22, 2012 at 6:21 pm
    In CS6 there are now Environment Layers that do the same kind of mapping. The might only be available in the new Ray Trace mode, however. I have not compared the two as to which is better.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Ali Khoshdouni
    August 22, 2012 at 6:34 pm
    I was trying for environment layer. but when i right click on jpeg layer in time line environment layer is desable for clicking.
  • Walter Soyka
    August 22, 2012 at 6:47 pm
    [ali khoshdouni] “I was trying for environment layer. but when i right click on jpeg layer in time line environment layer is desable for clicking.”
    You must be using the Ray-traced 3D renderer. CS6 does not do environment mapping in the default Classic 3D renderer.
    If you have VCP Element 3D, you could use that to add a camera-aware environment to a Classic 3D scene.
    Walter Soyka
  • Darby Edelen
    August 22, 2012 at 10:07 pm
    If you have After Effects CS6 then you should have Perspective > CC Environment, which does the same sort of AE camera aware spherical mapping as Trapcode Horizon (without the options for generating gradients directly in the effect).
    Darby Edelen
  • Chip Simons
    August 29, 2012 at 8:46 pm
    Check your render settings in the top right corner if it says Classic 3D change it to ray-traced 3d and the Environmental layer submenu item should become available. You should also have the image layer 3d turned on. Rendering will take considerably longer with ray-tracing though. Sorry, I did not see Walter’s post.
    -Chip Simons
