Activity › Forums › Apple Final Cut Pro Legacy › Is the occasional log and transfer problem normal?
  • Is the occasional log and transfer problem normal?
    Posted by Noam Osband on June 3, 2011 at 7:42 pm
    Rarely, I try to transfer some clips and FCP will start and then stop. When I go to look at the log and transfer screen, they have a red x next to them. I usually have to try 1 or 2 more times and then, eventually, the clips are transferred. Typically, it is a few clips on a card where most of them went off without a hitch.
    Is this normal? A sign of potential problems with the SD card? With FCP? It happens very rarely.
    Chris Wiggles replied 15 years, 3 months ago 3 Members · 2 Replies
  • Cody Walters
    June 4, 2011 at 12:32 am
    This has happened to me before. I’ve found that when you are doing log and transfer, you shouldn’t be doing much of anything else on your computer. I think it may be a bug in log in transfer.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Chris Wiggles
    June 4, 2011 at 7:42 am
    I had problems in the past with long clips when using an external USB drive while also connected with my camera via USB. Went away with SATA drives.
    Regards,
    Chris
