Activity Forums VEGAS Pro is the HDR-SR12 Off Topic??
  • is the HDR-SR12 Off Topic??
    Posted by Sean O’sullivan on September 21, 2009 at 6:56 am
    Hi guys,
    I could not see a Sony HD camcorder topic, and I thought some of you guys might be able to help me.
    I have an HDR-SR12 which is fantastic, and works really well with my Pro 8.
    But I ventured into Vista 64 territory and wiped my system and re-installed, now I have found that the One Touch Disc Burn has reset, that is that of the footage I have taken, (each time I burned progressively to DVD as a backup, (about 24-25 discs)) is considered new.
    The way it works is to just transfer the most recent clips, (since the last One Touch Backup) but now in my new system it has reset and is saying I need 18 discs to backup!!
    Some of these discs in the past were not full, so I see why it is less, but some I want to keep on camera, I always just want to burn the latest.
    I have a complete ghost of my old XP setup, which I can put back if needed (if the settings are in the registry,0 but surely these settings are available in the ghost for retrieval??
    Thanks guys,
    Sean O’Sullivan
    Sean O’sullivan replied 17 years ago 2 Members · 5 Replies
  • David Shirey
    September 21, 2009 at 4:57 pm
    Well this probably isn’t a bad place to ask since I know several of us have those model cameras. I have the SR11 but I never use any of the software it came bundled with. If you do have the WinXP files, could you just copy the program files over into Vista and see how it goes? Worth a shot.
  • Sean O’sullivan
    September 22, 2009 at 11:06 am
    Thanks David,
    Well the software is pretty good, ESPECIALLY that feature, as keeping a backup of any work just done, (without having to assess what is new and not backed up etc.) is awesome, also, the PMB is not too shabby, though a little ‘consumery’, but it has some really nice features, and while it was super-stable on my XP setup, the Disc Import was terribly buggy and even ejecting a disc caused a BSOD – but mostly the BSOD occured after the first import finished, a terrible senario, buat again, it was only for backup, fortunately that is not occuring on my Vista 64 setup, (same box and hardware).
    However in answer to your solution, I may just try that, the only problem is the possibility of corrupting the whole thing due tot eh different nature of the Program Files path for Vista 64 setups, now all 32bit software gets installed to C:\Program Files (x86)\ and the C:\Program Files\ folder now holds all 64 bit installs.
    I called Sony America, but they told me to call Australian support, the main reason I posted here was to see if any of you “connected” experts with sony software engineers might know how to get ahold of the original programmers to get this sorted and this important aspect (transffering settings to other PCs or installations) incoporated into the PMB/One Touch Disc Burn FAQ.
    I mean worse comes to worse, I have to delete my hard drive up until the end of the last disc I made, not a huge deal, but I see the fact I can store literally thousands of minutes of high quality family vids AS WELL AS full HD work vids is a real blessing.
    Sean O’Sullivan.
  • Sean O’sullivan
    September 23, 2009 at 3:48 am
    Ok guys,
    I found the files that detail where the camera is up too, and it is in the Sony Corporation folder in your Application Data path in XP, a folder called C:\Dcs and set…\Username\Application Data\Sony Corporation\Sony Picture Utility\Accessor then in Vista 64, this folder is in C:\Users\Username\AppData\Roaming\Sony Corporation\Sony Picture Utility\Accessor
    If you restore all of these folders and files between these locales it all carries everything over.
    Thanks guys, I hope this helps others, and Jay, you are close, but while this is like an incremental backup, it is built into the camera drive/software, and as far as a network drive/backup system, I combine that with a nightly ghost, a raw file copy of changed files to another drive nightly – with a backup program called MyBackup, and finally i secure things further by burning the ghost and raw files periodically to discs, soon to be blurays included).
    This feature of the HDR-SR12 Sony PMB suite is one of the most important aspects of HD video – that of media sensitivities, anyone who trusts a hard drive I have a bridge to sell you, i say spread the data, and there is more opportunitty for rescue as much as there is always opportunity for failure…
    Sean O’Sullivan.
  • Sean O’sullivan
    Ok guys,
    Sean O’Sullivan.
  • Sean O’sullivan
    September 23, 2009 at 12:28 pm
    Well, Jay, I really wish I could afford that setup right now, but for me it is just continuous accumulation of drives and software and the ‘arrangement’ that has me in this method, but I will be looking at that, especially if I get any large projects, at the moment I have not been doing anything of any significance to justify it.
    But on this ‘new’ topic, (I should start another thread, but we all knew this topic was off-topic by my subject line to begin with!), what then do you think of Drobo?
    Sean O’Sullivan
