Activity Forums Panasonic Cameras Is The HD-SDI of an HPX500 FULL HD?
  • Is The HD-SDI of an HPX500 FULL HD?
    Posted by Peter Tours on August 10, 2013 at 7:02 pm
    Besides, 720p does the HD-SDI output of the HPX500 put out full HD 1920×1080 or is it limited to 1280×1080? If the latter, does a KiPro uprez it?
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Convergence ECS1B 1977-1979
    Sony BVE 500 1979 – 1984
    Datatron Vanguard 1984 – 1993
    GVG VPE141 1993 – 1998
    Media 100 1995 – 2006
    Final Cut Pro 2005 to not too much longer
    Adobe Creative Cloud
    Reid Vanvoris replied 13 years, 1 month ago 3 Members · 2 Replies
  • Shane Ross
    August 11, 2013 at 7:53 am
    The signal coming out is full raster 1920×1080. Only the DVCPRO HD format is 1280×1080. If you send that signal to the KiPro, It’ll record full raster, 10 bit ProRes.
    Shane
    Little Frog Post
  • Reid Vanvoris
    August 12, 2013 at 6:12 pm
    I believe the SD-HDI out of the HPX500 is 8-bit. The KiPro records it as 10-bit, but the 4:2:2 color space is what will count most for the keying you’re trying to do.
    Reid VanVoris
    e-Mail: r1108@hotmail.com
