Activity › Forums › AJA Video Systems › Is the Dell 2407 or 2707 up to….
Posted by David Issko on February 18, 2007 at 7:52 pmthe challenge of being a reasonably accurate main hd monitor in a predominantly hdv sourced format environment, based on its price.
would it be better to spend the extra on the panasonic bt-lh2600 monitor?
thanks
davidDavid Battistella replied 19 years, 7 months ago 6 Members · 12 Replies -
Walter Biscardi
February 19, 2007 at 12:38 am[david issko] ”
would it be better to spend the extra on the panasonic bt-lh2600 monitor?”Absolutely. I have the Dell 2407 as my main computer monitor, but would never use it as a main HD monitor. Better to spend the money on a 42″ Panasonic Plasma screen instead of the Dell 2407.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Shane Ross
February 19, 2007 at 12:42 amWith the Matrox MXO you can get darn good colors. I have judged it next to my Sony PVM-14L5 and they are very close. With the addition of an Eye-2-one calibration kit, you can make that monitor a color correction monitor.
Shane
Littlefrog Post
http://www.lfhd.net -
Bob Zelin
February 19, 2007 at 1:14 amThe Dell 2407WFP is a great monitor, and looks teriffic for HD ONLY. It displays the full HD resolution, and works very well with the component output of the AJA products. It is horrible for standard def signals, however. A Sony HVRM-25U analog component HD signal looks great on this monitor. The Dell 2407 is the display used by the $8000 Terranex Clearview monitor.
The Panasonic TH-50PHD9UK that Walter refers to is fantastic, costs about $1799, and is a big 50″ monitor. A great product.
The Panasonic BT-LH2600W is a 26″ monitor, that will display up to a 1366×768 resolution (1080i looks very good, however). This is a very popular monitor, and has a built in “marginal but useful” HD waveform monitor. The unique part about this monitor is that Standard Def video looks very good on it. This monitor costs about $4000 at B+H.
If you have no money, and want to display HD only, the Dell is an excellent value. To repeat, if you intend to work in standard def resolutions, the image on a “Wal Mart $69 special” looks better than standard def on the Dell.
the rumors of the streaking noise in the 2407 was on the early release of this model, and there are no longer any issues.
Bob Zelin
Kevin Wild
February 19, 2007 at 2:25 amI have both the Dell 2407WFP and the Panny TH-50PHD9UK and I can say that I barely ever use the Dell any more. (Also, you should know that you need the BlackMagic DeckLink as well, to get a good SDI-DVI converter into the Dell…I guess an MXO would work, too, but I use the Decklink).
I’m with Bob that SD looks horrible on the Dell and is small on the screen as it’s pixel-pixel. 720 is also smaller on the screen. Only 1080i/p fills the screen. I’ve had trouble setting up the black levels as the Dell is very bright and the utility that comes with Decklink is pretty bad, imo. Also, with 24F footage from the Canon, the screen flickers a little bit. I’ve never gotten to the root of this problem as I now just use the Panasonic.
By the way…that Panny is down to $1799? Sheesh…take a breath…don’t look back, don’t look back…
Kevin Wild
http://www.drawbridge.tv -
David Issko
February 19, 2007 at 4:54 amThanks Walter,
Do you have the HD-SDI option installed as well?
David
David Issko
February 19, 2007 at 4:58 amAs you have stated on this forum many, many times before, I will need LOTS of money in this industry, however not many of us do have lots of money – me included, so the 42″ or 50″ plasmas seem like a great happy medium between cost and performance.
I asked Walter whether he has the HD-SDI option in his 42″ unit. Do you believe it necessary or will component do as an initial start?
David -
Kevin Wild
February 19, 2007 at 5:03 amNot to hijack your question, but component works perfectly fine. I have Component out going to a VAC D.A. and the HD feed going to several places and it all looks great. I wouldn’t pay the extra price for SDI, though others may disagree.
Kevin
Walter Biscardi
February 19, 2007 at 11:31 am[Kevin Wild] “By the way…that Panny is down to $1799? Sheesh…take a breath…don’t look back, don’t look back..”
and the 42″ is down around $1,200. Amazing how much they have dropped.
Walter Biscardi
February 19, 2007 at 11:32 am[David Issko] ”
Thanks Walter,Do you have the HD-SDI option installed as well?”
Nope, component only on both plasmas being fed by the Kona 3’s.
David Battistella
February 19, 2007 at 2:08 pmJust on the Component vs. SDI issue. I have seen an upclose comparison from a K2 Component vs. SDI through the original Full 1080×1920 Sharp Aquos. A Miranda box was doing the conversion and pulldown to (the sharp doesn’t recognize the 23.98 framerate). There was a huge difference in contrast and sharpness when viewing SDI vs. this DVI converter. It’s a much cleaner signal with more contrast.
two cents.
David
Peace and Love 🙂
