Activity › Forums › Apple Final Cut Pro › Is separating video files on different drives still necessary or recommended?
Ben Balser replied 2 months ago 4 Members · 15 Replies
Jeremy Garchow
July 22, 2026 at 5:53 pmYou can use target mode to transfer the footage to your current MacPro. I just would not try to edit the footage directly in target mode. FW800 is pretty slow, and I would imagine there will be some penalty for target mode, so I would transfer that footage from your G4 to your current MacPro in target mode, and then not use the g4 anymore for storage. Make sense?
Pierre Delafontaine
July 22, 2026 at 6:05 pmMakes sense, yes, especially that my G4 is only FW 400! ☹
So I think I’ll do that: transfer the original DV footage to the SSD, as it may speed up rendering of any effects, image corrections, text additions and things like that, and I’ll use the 1 TB HD for renders, which will always be used “as is”.
Thanks Devrim and Jeremy! 😊
Ben Balser
July 24, 2026 at 10:50 pmNo, it is not. Storage throughput is so far beyond what it used to be, back when that was necessary. But the answer to your op question is, “No, it is not.”
Pierre Delafontaine
July 26, 2026 at 9:18 amActually, I strongly suspected that modern machines, with their fast drives and buses, had made that video file separation unnecessary.
However, considering that only 7.5 years separate my mid-2002 PowerMac G4 and its PATA drives from my newly acquired early-2008 Mac Pro and its SATA drives, I was indeed wondering whether those 7 years had really made a difference regarding the need to separate video files as it was recommended to do back then.
So, thanks Ben and all who responded. 🙂
Ben Balser
July 28, 2026 at 2:03 pmLikewise, 2002 to 2008 isn’t much compared to the speed increases between 2008 and 2026. All the best to you.
