Activity Forums Adobe After Effects Expressions Is scripting in extendscript language-dependent?
  • Is scripting in extendscript language-dependent?
    Posted by Andrei Popa on March 13, 2018 at 8:06 am
    The title pretty mush says it. I have built some scripts but the problem is that they only work in english AE. I would like to change that, but i don’t really know where is the mistake. Is the scripting part language-depenmdent or only the expression part where i adress layers/properties?
    Andrei
    My Envato portfolio.
    Andrei Popa replied 8 years, 6 months ago 2 Members · 2 Replies
  • Dirk De jong
    March 13, 2018 at 11:04 am
    [Andrei Popa] ” Is the scripting part language-depenmdent or only the expression part where i adress layers/properties?
    As far as I know it’s only the properties which are language localized in the UI that you need to watch out for. The scripts/expressions should refer to parameters by index or param ID and effects by match name rather than UI name.
    Here is a web page I’ve used that lists match names for a lot of the AE standard effects ;
    https://www.redefinery.com/ae/fundamentals/effects/matchnames/index.php
    and there is an even more comprehensive list from David Torno available as a pdf download here ;
    https://www.provideocoalition.com/aftereffects-plugin-match-names/
    and on that same page a script is available which can output the match names for all plugins installed on your machine.
    and here is a script (available for sale) that can go read through the whole project and update expressions ;
    https://aescripts.com/expressionuniversalizer/
  • Andrei Popa
    March 13, 2018 at 2:35 pm
    Than you very much for this info. You spared me for hours of searching answers 😀
    Andrei
