Is RAID1 working? How do I set BIOS?
I have a Dell Alienware Aurora ALX purchased in Dec 2010, and I am not sure whether my RAID1 is configured properly.
The computer has an Intel ICH10R SATA RAID controller. The configuration that I ordered was supposed to have the boot drive set as a stand-alone drive and the data drive as a mirrored RAID1 array.
In Windows7 Device Manager, under Disk Drives, I see ARRAY0 (data drive) and ST32000641AS (boot drive.) In BIOS, I see 3 drives, one is the boot drive and the two others have the same identifier (ST31500341AS).
But, I am afraid that the RAID is not working because in the Intel Rapid Storage Technology window, 3 HDs are listed, but there is no indication that any of these are structured in an array. Under “Manage”, I can see the properties of each of the 3 HDs, but nothing about an array. Under “Usage” for each HD, it says “unknown”. Further, under “advanced” there are no options that can be changed. There is nothing to say that this is RAID1 or RAID0.
Within BIOS (A10), under Integrated Devices, the ICH SATA configuration was set by Dell to “configure SATA 1-6 as AHCI”. But, the other choice here is “configure SATA 1-6 as RAID”. Should this be set to RAID? I am afraid to change it because it says in red that this could make the SATA devices inaccessible to the OS. And, on the Intel website it says that this should not be changed after the operating system has been installed.
Is the RAID1 configured properly? How can I tell?
If it is configured properly, how do I manage the array? It seems that somewhere there should be a dialog that will let me set SATA1 as a single drive and SATA2-SATA3 as a RAID1.
Thanks.
