Activity › Forums › Apple Final Cut Pro Legacy › Is ProRes HQ a “capturing codec” ?
  • Is ProRes HQ a “capturing codec” ?
    Posted by Pierre on October 12, 2007 at 4:04 pm
    About to capture Varicam footage and would like to capture to best possible codec without capturing truly uncompressed. I just don’t have the hard drive space for it and don’t know if I could tell the difference anyway. I would however like to take advantage of the new ProRes codec.
    Can I use the ProRes codec to capture via HD-SDI out of a DVC-PRO HD deck?
    I don’t see the ProRes codec as an option in the “log and capture” window under “capture settings tab” .
    Does this mean that it’s a codec that I can apply to a sequence AFTER the footage is captured under another codec?
    Or am I just looking in the wrong place?
    thanks,
    michael
    Chris Borjis replied 18 years, 11 months ago 4 Members · 5 Replies
  • Shane Ross
    October 12, 2007 at 4:06 pm
    You need to have FCP 6 to do this, and an Intel Mac.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Pierre
    October 12, 2007 at 5:04 pm
    I’ve got final cut six and, a quad with 4.5 gigs of RAM and an AJA Kona 3 card.
    The quad won’t cut it? Must be intel?
  • Shane Ross
    October 12, 2007 at 5:09 pm
    To capture PRO Res, your machine MUST be an intel, or you must use some capture device with a hardware ProRes encoder like the AJA I/O HD.
    This has been tested and reported on in these forums.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Matt Steeves
    October 12, 2007 at 5:56 pm
    DONT do it. I made this mistake a while back and my Pro Res stuff will not play back properly for some reason- video was jumpy. I ended up having to convert all the stuff to 10-bit uncompressed. I suggest using DVCPRO/HD for now until Apple gets this codec in working order.
    -BTW every tech I talked to couldnt figure out my problem.
    Since I rented the deck, it was impossible for me to recapture into another codec, and I was stuck.
  • Chris Borjis
    October 12, 2007 at 7:26 pm
    There is nothing wrong with ProRes.
    It works perfectly fine for most people.
    I have used ProRes for SD since it came out and I wouldn’t
    go back to uncompressed again if I don’t have to.
    I can vouch for Shane’s ProRes HD testimony though, although
    Apple says a G5 Quad is minimum, it WILL not work
    on all of them, because mine consistenly fails
    to capture after 5 or 6 seconds. Some have been
    able to capture with G5 quads, but I’m not one of them.
