Activity Forums Apple OS X Is OSX 10.4.7 solid?
  • Is OSX 10.4.7 solid?
    Posted by Alden Brigham on September 7, 2006 at 10:24 pm
    I’m particularly interested in updating to 10.4.7 to get help from Bonjour in solving some of my local network problems. Has anyone updated and found unexpected problems w/Bonjour and or FCSP?
    thanks for feedback!
    Tony! Hulette replied 20 years ago 3 Members · 2 Replies
  • Simon Carlson-thies
    September 8, 2006 at 4:41 am
    This is the world of computers, whether you have problems or not has more to do with your system and how your stuff works together then anything else. Which has a lot to do with the fact that programmers only understand the interactions in 100 lines of code, and most software today is well over that… so one gets unexpected results… and therefor makes your question impossible to answer, in a truly meaningful way…
    And no I have not had problems with 10.4.7… but that says very little about the issue of whether you will…
    Simon Carlson-Thies
  • Tony! Hulette
    September 9, 2006 at 2:56 am
    Ditto, no problems with 10.4.7, but its unlikely that upgrading will instantly fix your network problems. Although, we don’t anything about your computers or how you are connecting them, it is possible if you upgraded them all to 10.4.7 it might be easier to setup your network with some of the built-in network troubleshooting tools. But without complete details there are way too many variables to even guess at what would help you.
    Tony!
