Activity Forums Apple Final Cut Pro Legacy Is Offline/Online Necessary For 2k?
  • Is Offline/Online Necessary For 2k?
    Posted by Brad Kester on December 10, 2015 at 9:01 pm
    I’m starting an edit on a short film. The clips I’m working with are ProRes HQ at 2K resolution (2048 x 1152). I’m wondering if FCP 7/my computer will handle this footage fine or if I should convert to 1080p and do an offline/online edit. The clips look fine in a test sequence but wondering if I will experience more problems down the road if left at 2K.
    If memory serves, the machine I’ll be editing on is a 2012 iMac with 8gb of RAM. Getting a bit older, but has always been a workhorse. And I’ll be working off a fast Glyph Studio RAID via Firewire 800.
    Any thoughts?
    Brad Kester replied 10 years, 8 months ago 4 Members · 5 Replies
  • Mark Suszko
    December 10, 2015 at 9:48 pm
    I personally would work with proxy footage and only import the full-rez at the final stages.
  • Shane Ross
    December 11, 2015 at 12:23 am
    2K is BARELY bigger than 1080. So going to 1080 isn’t really going “offline quality,” unless you lower the codec as well…say ProRes Proxy. If you have a fast enough drive, and more current computer with decent RAM, you might go for it. If it’s older, and slower, going to ProRes Proxy
    Shane
    Little Frog Post
  • Nick Meyers
    December 11, 2015 at 1:11 am
    yeah, i’d say test it.
    if it feels good on your older machine, then go for it.
    things to consider:
    exports, and moving files around will take a lot longer.
    how will your system cope w playing 2 streams? (simple composting, 2-cam situations)
    do you like to scroll through your rushes a lot? test that, it can be taxing
    if you want to go to a lower-res for offline, ProResLT 1280×720 is a nice way to go
    then you really do see some savings.
    nick
  • Brad Kester
    December 11, 2015 at 1:18 am
    Thanks for the input. Yeah, I was kind of wondering if the footage was big enough to make a difference at all. Think I’ll probably just go for it with the 2K clips. That seems like a better solution than storing a whole extra set of Proxy clips on my hard drive (because that’s what I would have to do, right?).
    BK
  • Brad Kester
    December 11, 2015 at 1:24 am
    Thanks for the extra feedback Nick. Didn’t see it before I posted my previous message. Will definitely watch out for those potential problem areas early on in the edit to gauge whether or not I should continue with the 2K clips.
    BK
