Activity Forums Adobe After Effects Expressions Is not an object error, but it doesn’t say what isn’t
  • Is not an object error, but it doesn’t say what isn’t
    Posted by David Cabestany on September 20, 2017 at 4:10 pm
    I’m getting the following error:
    But I can’t understand what is it that it’s not an object.
    Can anyone explain?
    Thanks.
    x=transform.position[0];
    y=transform.position[1];
    t=text.length;
    if
    (t>34)
    z=-89.2
    else
    z=-41.2
    [x,y,z];
    David Cabestany replied 9 years ago 2 Members · 4 Replies
  • Dan Ebberts
    September 20, 2017 at 5:21 pm
    I think you’re getting that error because there’s no semi-colon on the next-to-last line. But you have another error in your source text length reference. I’d do it like this:
    t=text.sourceText.length;
    z = (t > 34) ? -89.2 : -41.2;
    [x,y,z]
    Dan
  • David Cabestany
    September 20, 2017 at 9:46 pm
    Thanks Dan, Yes I noticed the semicolon and after I added it it was indeed fixed.
    Semicolons are tricky, sometimes you need them and sometimes they will break the expression.
    However, after that it works fine, what error are you referring to?
    Also, what are “?” and “:” in the conditional? Are those replacements for the flat and curly brackets and the else statement?
    Thanks a lot for your help.
  • Dan Ebberts
    September 20, 2017 at 10:05 pm
    t=text.sourceText.length; vs t=text.length;
    That’s the JavaScript Conditional (Ternary) operator–a more compact version of if/else
    Dan
  • David Cabestany
    September 20, 2017 at 10:13 pm
    Thanks!!
