Activity › Forums › Adobe After Effects › Is my cpu and computer goood for after effects
Posted by Hanna Dean on May 3, 2016 at 3:40 pmMike Poliskey replied 9 years, 9 months ago 5 Members · 23 Replies -
Michael Szalapski
May 3, 2016 at 6:50 pmYes. You might want to double your RAM.
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Michael Szalapski
May 3, 2016 at 6:51 pmDo you have a couple of SSD’s in there? You want some.
– The Great Szalam
Hanna Dean
May 3, 2016 at 7:06 pmhi sir am currently on sata , i might need to get some ssd , and what ram upgrades will you recommened me.
my pc can hold upto 64gb ram.is my pc good for rendering and performance
Michael Szalapski
May 3, 2016 at 7:19 pm32 would be better than 16. If you can get 64, it wouldn’t hurt to have that instead.
It depends on what kind of work you’re doing, but yes, it should work okay. Rendering in AE is a whole long discussion…
I usually work in CC 2015 and then render in CC 2014 to use the old multiprocessing, but that doesn’t apply if I’m using Element 3d, for example.– The Great Szalam
Hanna Dean
May 3, 2016 at 7:29 pmso is it good to work on cc 2015 for performance ? please tell me then later render it out using cc 2014
Walter Soyka
May 3, 2016 at 8:14 pm[hanna dean] “so is it good to work on cc 2015 for performance ? please tell me then later render it out using cc 2014”
My preference is to work in Ae CC 2015. The interactive performance is a lot better.
I render short things directly from Ae CC 2015 (since they are usually cached anyway), but longer comps from Ae CC 2014 with multiprocessing enabled.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Hanna Dean
May 3, 2016 at 8:39 pmif i enable multi processing will this speed up the render time, also speed up render is time line as i move through
Walter Soyka
May 3, 2016 at 9:17 pm[hanna dean] “if i save projects in cc 2014 can i open in cc 2015 vice versa”
Yes, they are 100% compatible. We do this all day, every day.
Walter Soyka
Walter Soyka
May 3, 2016 at 9:19 pm[hanna dean] “if i enable multi processing will this speed up the render time, also speed up render is time line as i move through”
Multiprocessing takes a little while to start up, but once it’s running, Ae can render multiple frames at the same time. For very short projects, it’s not worth the startup time. For longer projects, the startup time is paid back and then some with the faster overall render.
This applies for previews and renders in Ae CC 2014. It does not apply for just scrubbing the timeline.
Walter Soyka
