Activity Forums VEGAS Pro Is MPEG-2 compressing my audio?
  • Is MPEG-2 compressing my audio?
    Posted by Ryan Mcrobb on December 16, 2010 at 11:22 pm
    Hello all,
    When I render a video to MPEG-2 format(for use on DVD video’s) I need to be able to render to uncompressed audio (44.1Khz 16 Bit .wav file or higher).
    I ask because on the render window I get this view:
    What worries me is the “224Kbps” part of this picture. This gives me the impression that it is compressing the audio. It also doesn’t allow to take this compression off:
    What I would prefer is the dialog box shown in an .avi render, with no compression:
    If anyone can suggest a way to help me out that would be great!
    Regards,
    Ryan
    Dave Haynie replied 15 years, 8 months ago 2 Members · 1 Reply
  • Dave Haynie
    December 17, 2010 at 6:40 am
    You don’t usually render audio and video together when creating a DVD. Are you using DVD Architect, or something else? For DVD, you should use one of the profiles for “DVD Architect” under MPEG-2, to ensure you have DVD compliant video.
    As for audio, if you want PCM (uncompressed), just render to a WAV file, and load that separately in your DVD authoring program. There’s no reason to worry about creating a multiplexed MPEG file for DVD, since the DVD application is going to strip that container and create its own, anyway. And you can’t use 44.1kHz sampling; DVD requires 48kHz.
    -Dave
