Activity Forums VEGAS Pro Is Media Crop available?
  • Is Media Crop available?
    Posted by Oscar Paquette on August 23, 2022 at 4:15 am
    I see there are event, track and media FX available but I’m having trouble finding Media crop. I literally have 1000 individual sections of interview clips that I’d like to apply the same cropping to without having to set a crop on one clip then paste events to a hundred or so clips at a time. In retrospect, I probably should’ve cropped the main video exactly how I wanted BEFORE splitting the video hundreds of times (insert facepalm)
    Thanks!!!
    Oscar Paquette replied 4 years ago 2 Members · 2 Replies
  • Red-rob Rothkopf
    August 23, 2022 at 4:31 am
    Hi Oscar!
    I’ve often thought it would be great to have the exact thing you’re asking for.
    Although you can’t apply a “pan/crop” effect at the media level, here are a few ideas:
    1. Crop the first event on the timeline the way you’d like, then “COPY” the event. Right-click the event and choose “select in project media”, then right-click the project media (which that event is from) and choose “select all timeline events”. With all the timeline events now selected (which are using that media), right-click one of them and choose “paste event attributes”… done! OR use “selectively paste event attributes” to just paste the pan/crop without affecting other FX that might exist on those other events.
    2. If you’re OK with black borders, you can add a “cookie cutter” to the media (or track)
    3. Do similar to what you did in #1 (above) to select the events using that media, and put them onto their own track, then use the “Track Motion” to change the size of the events on the track
  • Oscar Paquette
    August 23, 2022 at 4:10 pm
    Option 1 worked!! Brilliant!!! You just saved me a TON of time!!! THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!
