Activity Forums VEGAS Pro is it worth pre-processing h.264 footage from an EOS dslr before using it on the vegas timeline?
  • is it worth pre-processing h.264 footage from an EOS dslr before using it on the vegas timeline?
    Posted by Terence Kearns on September 28, 2011 at 5:40 am
    I’m not sure I understand the reasoning for this. I know all the FinalCut users need to do this, but the footage from my 5DII and 7D all load into Vegas Pro 10 just fine. Why, then, would it make any difference to do colour-sampline up-sampling and eat up a lot of HDD space in the process?
    I’d like to know if there is any adavantage.
    Frederic Baumann replied 14 years, 11 months ago 3 Members · 2 Replies
  • Mike Kujbida
    September 28, 2011 at 2:12 pm
    I stand to be corrected but I think that FCP does a conversion to ProRes or some other format before importing the files.
    That’s not required in Vegas so continue to do as you’re doing and be happy about the time you’re saving 🙂
  • Frederic Baumann
    September 29, 2011 at 9:30 pm
    If you are thinking of Cineform Neoscene pre-processing, it looks like this tool is extracting information from the MOV file in a smarter way than Vegas does, so it is able to get more bits of information for every pixel, leading to better quality video.
    I must admit that I have personally skipped this step since I have upgraded to Vegas Pro 10 (I only bought Cineform because I got crashes with Vegas Pro 9 with my MOV files), saving conversion time and disk space.
    If you dig a little on the support site of Cineform, you will find more explanations. Shortly said, it is related to the fact that it is able to mix information between neighboring pixels, which helps reconstructing more accurate data, whereas Vegas does not do it.
    Another benefit is that the resulting AVI are easier to decode for Vegas, so the preview is slightly smoother than with MOV files.
    Hope this helps,
    Frédéric
    Want to Match Colors between clips? new plug-in here.
    Check GPU-powered FBmn Software plug-ins to fix White Balance and Exposure issues.
    Want to learn on Sony Vegas Event Pan/Crop tool? Watch my tutorial.
    Or about Keyframes? Watch this one. French version here.
