Activity Forums Blackmagic Design Is it time to get rid all of my old cards
  • Is it time to get rid all of my old cards
    Posted by Yasser Amin on May 6, 2010 at 7:21 pm
    Hello
    I have 3 station with 3 Declink Extreme PCI-X
    each one Windows7 32 Bit + CS4 + 4G Ram
    Now CS5 is native 64 bit and DeckLink_Windows_7.6.2 driver support CS5
    I know that there is a problem with this cards and Windows 64 bit with 4G ram “not working at all”
    and can’t reduce my memory to 2G “have 2 X 2G ram”
    Is the solution is to get rid of my 3 Declink Extreme PCI-X cards or I will get another solution from Decklink support guys
    regards
    Yasser Amin replied 16 years, 4 months ago 3 Members · 4 Replies
  • Nicky Van der walt
    May 7, 2010 at 7:56 am
    As far as I am aware the “4Gb RAM and card not working at all” in a 64 bit OS happens only with PCI versions of the cards.
    Not sure about PCI-X versions of the cards though, as I only experienced this with PCI versions of older Decklink SP cards.
  • Yasser Amin
    May 7, 2010 at 8:30 pm
    Hello nicky
    thank you for replay
    PCI-X cards working in PCI and PCI-X slot and have the same problem with 64bit windows “test it in Vista 64”
    am looking now for a solution to reduce the memory from 4G to 3G by bios or by increase hardware reserved memory in windows 7
    Does anyone has a suggestion
    still waiting for Decklink support guys opinion
    regards
  • Kristian Lam
    May 8, 2010 at 3:43 am
    Hi Yasser,
    Unfortunately, the PCI cards will not be able to support more than 4GB of RAM in a 64-bit operating system. This is not likely to change but all the current PCIe cards available now will work fine.
    You could potentially setup a few cheaper logging or capture workstations with the older cards.
    regards
    Kristian Lam
    Blackmagic Design
  • Yasser Amin
    May 11, 2010 at 2:40 pm
    Hello Kristian
    I think that you don’t read my first post
    I have 4G ram installed in my system and the card not working
    any way I solved my problem and all cards working now and I will not rid of my cards, but sure I will add a new HD workstation
    regards
