Activity Forums Apple Final Cut Pro Legacy Is it the RAM?
  • Posted by Glenn Pniewski on July 18, 2008 at 1:30 pm
    Here’s the unit:
    PowerMac G4
    OSX 10.3.9
    FCP 4.5
    Quicktime 7.5
    RAM slot 1 = 128MB
    RAM slot 2 = 512MB
    2 RAM slots open
    Help Help! The problem is that I cannot capture DV into Final Cut. The minute I hit CAPTURE NOW, Final Cut will freeze. Then after I power off and on, that particular capture file will be something like 10G. . .although it didn’t really capture anything. Obviously, I trash this. I have been told that this is a memory leak somewhere.
    Now. . .given my system and the RAM situation I outlined above. . .it has been suggested to me to get that RAM to at LEAST 2gig. So. . ..can I buy a 2 gig stick and just replace the 128MB? Or do I have to buy matched pairs?
    Do you think this is the problem?
    Interestingly, I can import DV into iMovie (which I would not even think of using), so I know it’s not a firewire problem or anything like that. I’ve even tried importing the .dv files (captured in iMovie) into Final Cut, but FCP doesn’t like it. . .needs to render audio, then it’s really clunky getting through the timeline.
    Would upgrading to 10.4 help?
    Actually this problem has gone on for the better part of a year, but after a few tries, I always got it to work. Now it won’t. And I can’t do a batch capture, because the sound on the logged/captured clips is way out of sync.
    I can supply more information if you need. . .I have a major project I need to start on this weekend and, needless to say, I need to import DV. It’s a must!
    Glenn
    I’m here all day. . .
    Zane Barker replied 18 years, 1 month ago 2 Members · 4 Replies
  • Glenn Pniewski
    July 18, 2008 at 5:51 pm
    I know I’m living on the edge with that little RAM, and I am going to get a 2gig stick tomorrow. And that was kind of the reason for the post, too. I didn’t know if I could just get a 2gig stick, or if I had to buy two 1gigs.
    Oh, yeah, it’s sluggish alright. Lots of burps when you play stuff back on the timeline, especially a project that is render-heavy. I’ve been meaning to add on, it’s just, as long as I was getting by, it dropped off the radar.
    Yes, right now I had the capture now setting for 30 minutes, but obviously that’s not working. I haven’t tried capturing in five minute increments, simply because that would be sooo much match editing that should be unnecessary.
    So, yeah, I believe you are saying get off of 4.5 and get to 5, which necessitates an upgrade to OSX 10.4. . .?
    Thanks a million,
    Glenn
  • Glenn Pniewski
    July 18, 2008 at 6:43 pm
    I have tried that and the sound gets WAY OFF sync, whether it’s a five minute clip or a twenty-minute clip.
    I phoned my partner and read him your reply about the RAM (or lack thereof) and he got a good laugh out of that. Yes, I am way behind the times, and subsquently, the eight-ball!
    Glenn
  • Glenn Pniewski
    Glenn
  • Zane Barker
    July 19, 2008 at 5:21 am
    More info on your machine please.
    Honestly I would be suppressed it it will even take a 2 gb chip of ram, I would be surprised if any G4 machine could take more then a 1 gb chip in any one slot.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
