Activity › Forums › DaVinci Resolve › Is it possible to view the all pictures as monochrome while setting the contrast levels?
  • Is it possible to view the all pictures as monochrome while setting the contrast levels?
    Posted by Andreas Ahston on July 5, 2014 at 4:00 pm
    It’s easier to se if the contrastlevels are similar if there are no colors. So I’m wondering if there is an option to disable the colors while setting the nodes for the contrast, and then turn them back on to do the color work afterwords? I realize that I could just copy paste a node with no saturation onto all the clips. But perhaps there is an easier way, or perhaps this is not really a good idea. Any thoughs.
    Eric Johnson replied 12 years, 2 months ago 3 Members · 2 Replies
  • Paul Provost
    July 5, 2014 at 5:14 pm
    You could switch you broadcast monitor to monochrome
    http://www.filmandtvcolor.com | colorist | Los Angeles, CA
    Twitter: @4kfinish
  • Eric Johnson
    July 6, 2014 at 7:33 pm
    What Paul said, but if you want an in Resolve solution, you could set a Track correction using the Monochrome setting in the Color Mixer.
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/ebjohnson/colorreel
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
