Activity Forums Adobe After Effects Expressions is it possible to us expression for exponential scale?
  • is it possible to us expression for exponential scale?
    Posted by Ryan Chan on April 27, 2005 at 3:21 pm
    hello Dan and everybody, i just wondered if it is possible to use expression to achieve the same result as using exponential scale, so, i can modify the from/to value more easily? say, from 25% scale up to 2500% in 5sec, how to write the expression for this interpolation? thanks
    ryan
    Mike Clasby replied 21 years, 4 months ago 4 Members · 4 Replies
  • Dan Ebberts
    April 27, 2005 at 3:46 pm
    Try this:
    v1 = 25;
    v2 = 2500;
    t1 = 0; //start time
    t2 = 5; //end time
    if (time <= t1){
      s = v1;
    }else if (time > t1 && time < t2){
      t = time - t1;
      T = t2 - t1;
      k = Math.log(v2/v1)/T;
      s = v1*Math.exp(k*t)
    }else{
      s = v2;
    [s,s]
    Dan
  • Andrew Kramer
    April 27, 2005 at 3:58 pm
    Dan this is very creative how you solved this. Do you think you can explain it a little bit. Also could this be done with a linked slider.
    so if you keyframed the expression slider value at say 10 and then to 100 equal to scale would be 100-10000.
    this way you could alter it visually with keyframes.
    thanks
    Andrew
  • Ryan Chan
    April 28, 2005 at 1:53 am
    thanks Dan, you,re incredible! although it is far more complicated than i expected, but i will try to “Digest” this expression, thanks again.
    ryan
  • Mike Clasby
    April 28, 2005 at 8:01 pm
    Very cool little expression. It looks great on a 3D solid in Custom view 1, so you can actually see what’s going n. Thanks.
