Activity › Forums › Adobe After Effects › Is it possible to upload Affter effects projects into Avid editing?
  • Is it possible to upload Affter effects projects into Avid editing?
    Posted by John Boskamp on September 6, 2011 at 3:52 am
    I was just wondering if after affects is compatible with avid. If it can be done I would like to know how.
    Andrew Jehan replied 14 years, 2 months ago 4 Members · 3 Replies
  • Ben G unguren
    September 6, 2011 at 6:05 am
    Normally you simply render out an AE timeline into a self-contained movie file, and import that into Avid. Not sure why you’d bring AE into Avid, as you’d almost certainly do your editing in Avid, and in most cases it isn’t feasible to translate AE filters and features into the Avid workflow.
    However, Automatic Duck (https://www.automaticduck.com) can import Avid projects into AE (so you can have all the clips arranged in the AE timeline, etc). Or, if you have Premiere, you can export an AAF out of Avid, import that into Premiere, and then send it from Premiere into AE. A bit muddled, but workable….
    I do a lot of AE work with Avid, and the general workflow is as follows:
    1. Edit a rough in Avid, mock up graphics if desired (or put in title cards as stand-ins, etc).
    2. Export a lo-res QT movie from Avid as reference. Export timeline via AAF/Premiere or Automatic Duck to AE (if needed).
    3. Import clips and Ref QT into AE. Do all the effects work.
    4. Render out hi-res video, import that into Avid.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Niccolò Ungaro
    September 6, 2011 at 10:29 pm
    There are even more option that you can try…:
    https://forums.creativecow.net/readpost/2/1005200
    I will not forget tis time to ad to magnum script Trim Compose AE Script from Video Copilot: https://www.videocopilot.net/blog/2011/05/new-tutorial-trim-compose-script/
    Avid>AF & viceversa work well only with .mfx files that you can drag&drop straight on AF progect pannel at you nead….
    More rife: https://www.video2brain.com/en/videos-1927.htm
    avid_users_premiere_pro.pdf
    https://tv.adobe.com/watch/adobe-presentations-2009/open-workflows-between-avid-and-adobe-cs4-production-premium/
    Last but not least….: Media Access v2 – Avid® Media Composer https://vimeo.com/15967288 …xxx…
    Salutoni e un grande in bocca al Lupo da Ungars
  • Andrew Jehan
    July 26, 2012 at 6:59 am
    What’s the value of the lo-res reference QT if you have the actual edit with the real clips from the AAF import?
