Activity Forums Adobe After Effects Expressions Is it possible to take composition screenshots using scripts?
  • Is it possible to take composition screenshots using scripts?
    Posted by Noelia Sanchez on May 17, 2018 at 8:36 pm
    Hello,
    I am trying to create a personal script, to put the tools I use most together, and I would like to add a button that saves a screenshot of the active composition in a given folder from my computer… Is there a way to make this using scripts? This means that I will need a settings button where I have to input the folder where I need the images to be saved and a second button that saves the image in png format.
    Can anyone help me, please?
    Thank you in advance!
    Frederic Antoinette replied 8 years, 3 months ago 2 Members · 1 Reply
  • Frederic Antoinette
    May 23, 2018 at 2:57 am
    If you are looking for a screenshot of your whole application that is with your timeline etc… I’m don’t think you can do that within after effects. You need another application.
    On windows I use snipping tool, or record my whole screen using OBS.
    On the other hand if you want just the compisition, You could simply use Composition -> Save frame as.
    It will add to the render queue. You can create a default template so it automatically makes a png to a location of your choice.
    But then you’ll have to render your queue.
    However I’m pretty sure you can also automate that process through a script so that it does all that at the click of a button.
