Activity › Forums › Adobe After Effects › Is it possible to subtract a shape from a repeated shape using merge paths
  • Is it possible to subtract a shape from a repeated shape using merge paths
    Posted by Robert Anderson on December 12, 2018 at 11:42 pm
    Hi
    Is this possible or impossible?
    Have created a rectangle with single fill, repeat the object so there are multiple squares.
    And I want to use Merge Paths to subtract / intersect another shape from the repeated result.
    Any creative solutions or arrangement to the layers that would make this work?
    Currently have
    GROUP :
    • rectangle
    • repeater
    • fill
    • new path <–
    • merge paths <– subtract/intersect
    have also tried
    MAIN GROUP:
    SUBGROUP:
    • rectangle
    • repeater
    • fill
    • new path <–
    • merge paths <– intersect/subtract
    subtracting through the repeater seems to see the repeater as an object and then hides everything
    any possible ideas that don’t involve creating a separate layer with a mask?
    Kalleheikki Kannisto replied 7 years, 9 months ago 3 Members · 2 Replies
  • Marko Suto
    December 13, 2018 at 3:57 pm
    Have you tried precomposing the repeated shapes and then applying the mask on the precomp?
  • Kalleheikki Kannisto
    December 15, 2018 at 5:37 pm
    Depends on what you’re trying to do, but making the second rectangle the color of the background would “hide” it.
    Senior Graphic Designer
