Activity › Forums › Adobe Premiere Pro › Is it possible to step forward/backward by field?
  • Ann Bens
    August 27, 2014 at 7:14 pm
    No, but why do you want to do that?
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Michael Klaumann
    August 27, 2014 at 7:26 pm
    As an online editor sometimes I need to check for a flash field just before a cut and being able to step through the fields makes it easy to do that. Also I can check for reverse field issues. And if I need to pull a still frame from material that has a pulldown in it I can check for a frame that has the same field twice so I don’t get a frame with motion in the fields.
    Michael
  • Jeff Pulera
    August 27, 2014 at 8:12 pm
    In the Program Monitor window options, under FIELDS, you’ll find options for First, Second, or Both, if that helps.
    Jeff Pulera
    Safe Harbor Computers
  • Michael Klaumann
    August 28, 2014 at 7:24 pm
    Yes that actually will work, thanks!
