Is it possible to smart render this video?
I’m editing a video with the profile listed below but I can’t seem to get it to smart render and export the same video track(not re-encoded). When I re-encode it I lose a good bit of quality while the file size increases significantly. I have Premiere Pro CS6 on my PC.
Format: AVI format
Stream count: 2
Duration: 00:22:57
Bit rate: 986 kb/s
Meta info:
encoder: Lavf52.32.0Stream 0
Type: video
Codec: mpeg4
Codec profile: Simple Profile
FourCC: DIVX
Duration: 00:22:57
Width: 720
Height: 576
Sample aspect ratio: 1:1
Display aspect ratio: 5:4
Pixel format: yuv420p
Frame rate: 23.98 fpsStream 1
Type: audio
Codec: mp3
FourCC: U[0][0][0]
Duration: 00:22:47
Bit rate: 128 kb/s
Sample rate: 44100 Hz
Sample format: s16
Channel: 2
