Activity › Forums › Adobe Premiere Pro › Is it possible to slip a clip 1/2 frame so audio will sync?
  • Is it possible to slip a clip 1/2 frame so audio will sync?
    Posted by Don Cobble on February 8, 2014 at 3:07 pm
    I did a 2 camera shoot. One Cam wireless microphone second cam built in microphone. I cant get the audio waves to line up. I am either a frame early or a frame late. It creates a kind of echo. is there a way to slip the audio about 1/2 frame or cut a 1/2 frame off clip so I can get them line up?
    Thank You
    PC 1
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro K2000
    PC 2
    I7 3930K 3.2Ghz
    32 GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Vegas 10 64bit & Vegas 11 64Bit & Vegas 12 & Adobe Production Premium CS5.5.2 & Avid Media Composer 5.5
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Declan Smith replied 12 years, 7 months ago 3 Members · 4 Replies
  • Ann Bens
    February 8, 2014 at 3:59 pm
    You can cut audio up to 1/48000 of a second. Video cannot be cut or moved less then 1 frame.
    Set timeline to audio units (panel menu timeline) for easy editing.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Declan Smith
    February 8, 2014 at 4:16 pm
    Yes it is possible to line up audio exactly. Go to the program monitor, click the drop down menu and select ‘audio units’ (not sure of the exact name as I am away from my computer). Your time line will now allow you to move audio at a sample level resolution . When done, switch the setting back.
    Declan Smith
    https://www.madpanic.tv
    After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    “it’s either binary or it’s not”
  • Don Cobble
    February 8, 2014 at 4:58 pm
    Ok I found the setting to switch to units – do I need to un-sync or un-link it from the clip to move it?
    Thank You
    PC 1
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro K2000
    PC 2
    I7 3930K 3.2Ghz
    32 GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
  • Declan Smith
    February 8, 2014 at 6:18 pm
    You can use the slip tool (Y) which will slip the audio in place or you can unlink , move just the audio then relink, or make sure nothing is selected, then alt or opt click the audio track (this selects just the audio), then move the audio as necessary.
    Declan Smith
