Activity Forums DaVinci Resolve Is it possible to run Resolve 9 and Lite?
  • Is it possible to run Resolve 9 and Lite?
    Posted by John Vogel on June 13, 2013 at 9:08 pm
    Hello,
    I’ve got a Blackmagic Cinema Cam and my Resolve v9. Problem is the USB dongle. I run it on my laptop and carrying the dongle is a complete pain.
    For what I do, I can do it with Lite and is there a way to run both on the same partition?
    John
    Local Productions replied 9 years, 7 months ago 8 Members · 12 Replies
  • 12 Replies
  • Timo Teravainen
    June 13, 2013 at 9:21 pm
    Depends on what you do. If you don’t need noise reduction and more than HD output on your laptop, just run Lite. You can’t run both, not without dual boot to different partitions.
  • John Vogel
    June 13, 2013 at 9:25 pm
    Thanks Timo, I just downloaded Lite, installed and it just opened without a problem with all my projects from Resolve still in tack. I figured a partition was in order. Only HD output for me at the moment.
    Thanks again,
    John
  • Chris Kenny
    June 14, 2013 at 3:07 am
    [Timo Teravainen] “Depends on what you do. If you don’t need noise reduction and more than HD output on your laptop, just run Lite. You can’t run both, not without dual boot to different partitions.”
    I do really wish they’d set it up so Resolve would just run as Resolve Lite when the dongle wasn’t attached, instead of having two separate apps.
    Digital Workflow/Colorist, Nice Dissolve.
    You should follow me on Twitter here. Or read our blog.
  • John Vogel
    June 14, 2013 at 3:17 am
    Great idea!
  • Sascha Haber
    June 14, 2013 at 7:45 am
    That would enable the hackers to simply fake the dongle ID.
    If you offer free software most people wont bother.
    A slice of color…
    Resolve 9.1.1 OSX 10.8.2
    Colorist / Aerial footage producer
    https://vimeo.com/saschahaber
  • Neil Sadwelkar
    June 15, 2013 at 4:32 am
    I run Resolve Lite and Resolve on one machine. Use Resolve Lite to open projects which are HD and simple and I need to continue work on another system that doesn’t have Resolve full.. I run Resolve full when 2k or over, or if NR is needed.
    Works fine. I just have to be careful to upgrade both together.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • John Vogel
    June 15, 2013 at 7:26 am
    On the same HD?
  • Rohit Gupta
    June 15, 2013 at 9:33 am
    This is not possible as both of them use the same app name and share resources. Copying the app bundle to a different folder is not recommended and it will cause issues.
  • Mike Halper
    July 15, 2013 at 12:13 am
    Neil, could you describe how you accomplished this? Have you experienced any issues at all? Thanks.
  • Neil Sadwelkar
    July 15, 2013 at 6:39 am
    I installed Resolve Lite and worked on it for a few weeks. When I needed larger than HD projects I went out and bought Resolve full.
    After I had installed Resolve Lite, I had an app called DaVinci Resolve in the Applications folder. I renamed that to DaVinci Resolve Lite.
    Then I installed Resolve full. So, now I have two apps in the Applications folder DaVinci Resolve Lite, and DaVinci Resolve.
    I run Lite or Full depending on the kind of project I need to work on. In either, all projects are visible. Any project that starts in Resolve full won’t open in Resolve Lite. Any project that starts in Resolve Lite opens fine in Resolve full. But I don’t mix the two.
    When an upgrade is available, I download both Lite and Full. I backup the database, just in case.
    Then, I first run the full installer and uninstall the full version. Then rename the DaVinci Resolve Lite app back to DaVinci Resolve. Then I run the Lite installer and uninstall the Lite version.
    Next, I install Resolve Lite. So again I have an app called DaVinci Resolve in the Applications folder. I rename that to DaVinci Resolve Lite.
    Then I install Resolve full. This gives me an App called DaVinci Resolve in the Applications folder. So, now I have two apps in the Applications folder DaVinci Resolve Lite, and DaVinci Resolve. As before, I run Lite or Full depending on the kind of project I need to work on. In either, all projects are visible.
    I’ve done this since v 8.2 and through all the upgrades and it works just fine. I have no users created in Resolve and all my projects are in Admin. I’m doing this on a MacPro with 16 GB RAM and a Quadro 4000 card installed.
    As in any such things, YMMV.
    Neil Sadwelkar
    twitter: fcpguru
    Mumbai India
