Activity › Forums › VEGAS Pro › Is it possible to not select the file extension when renaming files in Vegas?
  • Is it possible to not select the file extension when renaming files in Vegas?
    Posted by David Bernal on February 11, 2020 at 7:34 am
    Is it possible to not select the “.mp4” part when I double click on the file to rename it?
    Wayne Waag replied 6 years, 7 months ago 3 Members · 3 Replies
  • Graham Bernard
    February 11, 2020 at 2:05 pm
    [David Bernal] “Is it possible to not select the “.mp4″ part when I double click on the file to rename it?”
    What happens when you try?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • David Bernal
    February 12, 2020 at 2:01 am
    When I double click on the file name it selects the whole name including the file extension so I have to carefully select the file name without the “.mp4” otherwise it deletes the files extension and says “If you change a file name extension, the file may become unusable”
    I can still change the file names but its very tedious having to make sure I deselect the “.mp4” especially if I have 50 files I need to rename.
  • Wayne Waag
    February 12, 2020 at 4:12 am
    If you have lots of files to rename, you might try the MediaRenamer tool in HappyOtterScripts. Here is a screen grab. It permits the bulk renaming of files with quite a few renaming options.
    At the moment, HOS is still in beta through mid-March. You can download a trial here. https://tools4vegas.com/
    wwaag
