Activity Forums Adobe After Effects Is it possible to merge down brush strokes?
  • Is it possible to merge down brush strokes?
    Posted by Daniel Haskett on May 15, 2005 at 12:01 pm
    Hi there
    Basically I want to be able to merge down a few brush strokes into one large brush stroke so that I can then make this into a mask, but I dont know how, and Im not even sure if this is possible…..umm is it?!
    Dan
    Jeff Cochran replied 21 years, 4 months ago 3 Members · 2 Replies
  • Filip Vandueren
    May 15, 2005 at 2:30 pm
    Is there an absolute need to ?
    You can just keep the brushstrokes an a layer, and use that layer as a trackmatte.
    There’s also the option of painting the alpha, so perhaps you don’t even need two layers.
    Thing is when you convert a brush stroke to a mask, you get the center path of the stroke, not the shape defined by it’s width and brush-shape if you understand me.
  • Jeff Cochran
    May 15, 2005 at 11:20 pm
    You could try pre-composing the layers with the brush strokes and using the new comp as the mask
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
