Activity › Forums › Maxon Cinema 4D › Is it possible to make the display lines of a polygon edge thicker in C4D for better visibility?
  • Is it possible to make the display lines of a polygon edge thicker in C4D for better visibility?
    Posted by Lucas Schwartz on March 25, 2019 at 11:34 am
    Hello,
    Is it possible to make the display lines of a polygon edge thicker in C4D for better visibility? I looked into the settings under options –> configure all –> view but I can’t control the line thickness from there.
    Lucas
    Steve Bentley replied 7 years, 6 months ago 3 Members · 6 Replies
  • Steve Bentley
    March 25, 2019 at 5:25 pm
    I don’t think you can change the thickness (that would make doing other things harder with a great thick line depicting something that has no dimension) but you can probably change the color – preferences/schemecolors
  • Lucas Schwartz
    March 25, 2019 at 7:15 pm
    Steve, thank you for your response. I have found the relevant setting to change the colour of the line however that’s not what I am looking for. I would like to change the “thickness” of the line.
    Take a look at the picture below.
    It is a snapshot from the tutorial I am using to learn hard surface modelling. The lines appear to be much more thicker and prominent than the default setting in my version of Cinema.
    There must be a setting somewhere within C4D to control the line thickness.
  • Lars Jandel
    March 25, 2019 at 7:26 pm
    You could lower your screen resolution. This will increase the size of UI elements like texts and icons and your lines should become thicker as well. Good luck!
  • Steve Bentley
    March 25, 2019 at 7:30 pm
    Referencing Lars’ comment, it, because its a video tutorial, perhaps the resolution of the screen was reduced for capture and the compression is making the lines a little thicker. You can also make the background color darker which would help with contrast. Is there a reason you want them thicker?
  • Lucas Schwartz
    March 25, 2019 at 7:44 pm
    Steve, once again thank you for you response. The reason I want the lines to be thicker is simple because I find thicker lines more comfortable to look at and easier to view when I work with the software for long hours.
    If there is no way to adjust the line thickness though other then adjusting the resolution of my screen I guess I just have to put up with it as it is.
    I was just hoping that there would be a built in setting in Cinema to control the thickness of the lines much like we can adjust the size of the polygons points and point handle size via the “options” –> “configure all” –> “view” setting.
    Thank you.
    Kind regards,
    Lucas
  • Steve Bentley
    March 25, 2019 at 8:05 pm
    I hear you. I’ve been complaining for years about the ever increasing screen resoluions and the ever decreasing size of icons and my againg eyes.
    In this case I find thinner the better (for accuracy). I even turn off the “never aligned” bounding box.
    But i’m pretty sure you can’t thicken it up. What about changing it to a bright yellow green- it’s the color the eye sees best. (think safety vest color)
