Activity › Forums › Adobe Premiere Pro › Is it possible to make layouts for footage?
  • Is it possible to make layouts for footage?
    Posted by John Kismet on July 18, 2023 at 9:08 pm
    Sorry if the title isn’t clear, not sure what the proper verbiage is which has made searching non fruitful (though I did try a few different queries)
    My situation is a series I make involves 3 recordings overlayed on top of each other. The “A ftg” is full screen of me, the “B ftg” is a different angle of me, and the “C ftg” is whatever I’m playing.
    I often switch from showing A & B ftg taking up the whole screen equally in a particular layout (<-layout 1)
    to showing C ftg full size and overlaying A & B in the corners with a mask to cut out what’s non-essential (<- layout 2)
    To make this work I make the layouts manually when I start editing the video, then copy & paste the motion and opacity from a previous clip. It’s not the worst, but I’m hoping there’s a way to make this more efficient by making the layout once then importing it into each new project and each ftg will fall into place with the template.
    Thanks for reading, any insight is appreciated and I’m happy to clarify if needed.
    Mads Nybo jørgensen replied 3 years, 2 months ago 3 Members · 2 Replies
  • Walter Soyka
    July 18, 2023 at 9:40 pm
    Sounds like you want to switch among multiple camera angles and add a few repeated PIP layouts?
    In cases like this, I like to build each layout as its own sequence, running the entire duration of the footage. Next I’ll render each layout out, re-import the renders, drop them in a multi-cam sequence with the full-frame sources, and finally use the multi-cam feature to cut.
    July 23, 2023 at 11:49 am
    Adding to Walter’s excellent advice, I would suggest that you investigate:
    1) Save your A and B camera effects settings as a preset in the Effects panel.
    2) Either combined with a preset, or separately, put your A and B camera (MultiCam?) into a subsequence that you can chop up, and edit, but apply the right preset to it when needed.
    “Scene Edit Detection”, an often missed but excellent feature, might be able to identify your edit points on the subsequence track in-vision camera edit.
