Activity Forums Adobe After Effects Expressions Is it possible to make an array available to other layers via expressions
  • Is it possible to make an array available to other layers via expressions
    Posted by Arne Münch on January 24, 2013 at 2:29 pm
    Hi everybody
    I have written an expression to write an array of non repeating values lets say from 1 to 20 into an array like in the attached code (Put this to an expression slider control)
    It works pretty well. But how you can see, the only possibility I saw for saving these values and make them accessible was by connecting each value to a specific frame in the time line(“my_array[t];” access it via the “valueAtTime” expression)
    But this can lead to very long expression calculation times, because every frame has to calculate all the calculations from scratch.
    Is there a way, other layers can link to specific values of a more than 4 dimensions array via expressions directly.
    Something like:
    thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”).var(my_array[5]);
    Hope this is clear enough. Otherwise please ask.
    thanks so much.
    tot = 20;
    t = timeToFrames(time);
    pool =[];
    my_array = [];
    if (t<1||t>tot){123456}else{
    seedRandom(1,true);
    for (i=0;i
    Dan Ebberts replied 13 years, 7 months ago 2 Members · 3 Replies
  • Dan Ebberts
    January 24, 2013 at 3:01 pm
    I think the closest you can come would be to create an expression on a text layer that creates the array as, for example, comma-separated text. Then your receiving expression retrieves the text string, does a .split(“,”) to break the text into an array of strings, and then a parseInt() to convert the desired element to a number. I don’t know if the performance would be any better that what you have though.
    Dan
  • Arne Münch
    January 24, 2013 at 4:07 pm
    Hallo Dan
    thanks for your reply, I tested your way and the performance seems in fact to be even worse.
    That means that long arrays are not meant to be stored and accessible via expressions in a proper way, aren´t they?
  • Dan Ebberts
    January 24, 2013 at 4:13 pm
    That’s correct. Expressions can’t really store anything and can only communicate with other expressions via the calculated value of the property hosting the expression.
    Dan
