Activity Forums Adobe After Effects is it possible to loop a still image?
  • is it possible to loop a still image?
    Posted by Luger54 on November 27, 2006 at 8:24 pm
    hello
    i would like to find out if i can loop a still image by adjusting its position and making it bleed off the composition window.
    I would like to loop this positioning, so as soon as the image starts bleeding off, it comes on again on the other side and so on.
    I could only do it with a sequence of images. Can it be done with one image at all?
    Luger54 replied 19 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 27, 2006 at 8:36 pm
    It sounds like you need to check out the Offset effect (in the Distort group, I think)
    Dan
  • Luger54
    November 27, 2006 at 10:09 pm
    WOW! amaizing stuff Dan!!!!!! Thanks
    Greg
