Forums › Adobe After Effects Expressions › Is it possible to link any effect value to a grayscale map?
Man Singh
January 17, 2022 at 12:57 pmCan we use luminance of a black & white layer to define which areas should have an effect applied? For example, can we apply turbulent displace to a layer than use a precomposed fractal noise layer to define how much turbulent displace has to be applied & to which areas of the layer?
Filip Vandueren
January 18, 2022 at 3:02 pmIn this case, you could replicate turbulent displace with a regular displacement effect that references a noise map.
You can then use a 2nd fractal noise layer to mix in patches of 50% gray: 50% = no displacement.
Man Singh
January 19, 2022 at 4:06 pmI used turbulent displace only as an example. I want a method where I can link intensity/slider value of any effect to luminance of a luminance map.
Log in to reply.
