Activity Forums Adobe After Effects is it possible to import premier project into a.e as seperate layers?
  • is it possible to import premier project into a.e as seperate layers?
    Posted by Jonny Tully on April 22, 2006 at 12:55 pm
    hello there, ive got the adobe production bundle and its great, the dynamic link feature is incredible (if not a bit cpu hungry) but i was wondering, when importing from premier pro 2 to a.e 7 is it possible to bring the prem file in as it is in premier; transitions etc.
    https://www.automaticduck.com/products/piae/
    offer a plug in that allows you to import from fcp or avid with all the transitions and they are customisable but when i import from premier, a.e just displays one layer which i then have to cut up at the right points to apply filters to..
    another advantage of importing as seperate layers would mean i could grade or effect a clip that is being disolved etc.
    hope someone can help 🙂
    Jonny Tully replied 20 years, 4 months ago 3 Members · 3 Replies
  • Deleted User
    April 22, 2006 at 11:59 pm
    Hello,
    You should be able to import as Premiere Pro project file then each cut should be outset and recreated the exact edit you had in Premeire pro. However I know it adds the transitions but I do not know if it takes all transitions as it still does not see the Premiere Pro text as in AFter Effects comes in as a blank layer whoch is annoying seeing made by the same company.
  • Jeff Baker
    April 23, 2006 at 4:19 am
    I think adobe has a list somewhere of which aspects of premiere will be imported and how. I get separate layers for each clip and transition on imports.
    Jeff Baker
    Three Geese Productions
    Oakland CA
    http://www.threegeese.com
  • Jonny Tully
    April 23, 2006 at 9:52 am
    thanks very much for the replies!
    ive worked it out now… by copying the timeline in premier then pasting it into a.e ive gotten what i was after 🙂 before i was clickiing file>import and selecting the prem file
