Activity Forums Adobe After Effects Expressions Is it possible to have an expression linking keyframes to a time remapped layer?
  • Is it possible to have an expression linking keyframes to a time remapped layer?
    Posted by Daniel Haskett on November 16, 2007 at 6:08 pm
    Hi there
    Basically, say you have a layer, and you use time remapping and youve got your 2 keyframes that specify how much you want played….
    Ok and then if you have a load of keyframes on a layers rotation say, is it possible to link the time remapped layer to these rotation keyframes?
    so say, whenever the rotation is more than 5 degrees, it will trigger the beginning of the time remapped layer to play. and then it will play through. and then it will do this whenever the keyframe is above 5 degrees, once its played through…
    does this make sense?
    hopefully someone can help!
    thanks
    dan
    Brad Pickford replied 14 years, 11 months ago 3 Members · 11 Replies
  • 11 Replies
  • Dan Ebberts
    November 16, 2007 at 7:10 pm
    A time remapping expression like this should work:
    threshold = 5.0;
    rotVal = thisComp.layer(“Rotation Layer”).transform.rotation;
    above = false;
    frame = Math.round(time / thisComp.frameDuration);
    while (true){
    t = frame * thisComp.frameDuration;
    if (above){
    if (rotVal.valueAtTime(t) < threshold){ frame++; break; } }else if (rotVal.valueAtTime(t) >= threshold){
    above = true;
    if (frame == 0){
    break;
    frame–
    if (! above){
    t = 0;
    }else{
    t = time – frame * thisComp.frameDuration;
    Dan
  • Daniel Haskett
    November 16, 2007 at 7:40 pm
    hey dan
    thanks for your help, i just tried that now and it works well. however it only plays the time remapped layer once. is it possible so that whenever the layer rotates past 5 degrees it will play the time remapped layer again?
    thanks again
    dan
  • Daniel Haskett
    November 16, 2007 at 7:42 pm
    OOOPS! sorry please ignore that last post, i had the expression turned off so it was only playing once. just turned it on and it works great, thanks dan!
    dan
  • Daniel Haskett
    November 16, 2007 at 7:47 pm
    actually sorry dan, just one more thing…./
    is there a way so that when the rotation goes below 5 degrees, it will make the time remapped layer go back to its first frame?
    thanks again!
    dan
  • Dan Ebberts
    November 16, 2007 at 8:33 pm
    This should do it:
    threshold = 5.0;
    if (rotVal < threshold){ 0 }else { above = false; frame = Math.round(time / thisComp.frameDuration); while (true){ t = frame * thisComp.frameDuration; if (above){ if (rotVal.valueAtTime(t) < threshold){ frame++; break; } }else if (rotVal.valueAtTime(t) >= threshold){
    above = true;
    if (frame == 0){
    break;
    frame–
    if (! above){
    0;
    }else{
    Dan
  • Daniel Haskett
    November 16, 2007 at 9:04 pm
    Thanks Dan, you’re a legend!
  • Brad Pickford
    October 10, 2011 at 8:54 am
    Hi Dan, I am trying to use this expression but I am getting the following error message…
    After Effects warning: Expected: )
    Expression disabled.
    Error occurred at line 6.
    Comp: ‘51_dad_isp_truck 02’
    Layer: 9 (‘spray’)
    Property: ‘Time Remap’
    Can you help?
    Thanks, Brad
  • Dan Ebberts
    October 10, 2011 at 5:45 pm
    Please post the expression that’s generating the error.
    Dan
  • Brad Pickford
    October 10, 2011 at 9:52 pm
    Here is the expression which is on the the Time Remap property…
    threshold = 5.0;
    rotVal = thisComp.layer("51_divider_horiz").transform.rotation;
    if (rotVal
    0
    }else {
    above = false;
    while (true){
    if (above){
    frame++;
    break;
    above = true;
    if (frame == 0){
    break;
    frame--
    if (! above){
    0;
    }else{
    time - frame * thisComp.frameDuration;
  • Dan Ebberts
    October 10, 2011 at 10:04 pm
    It looks like you’ve only got part of the 5th line. Sometimes lines that contain a less-than character get mangled.
    Dan
