Activity Forums Blackmagic Design Is it possible to get this to work?
  • Is it possible to get this to work?
    Posted by Johan Windh on January 15, 2013 at 2:53 pm
    Hi there,
    I currently work on the following system:
    CPU 2 x 2,8 GHz Quad-Core Intel Xeon
    RAM 8 GB 800 MHz DDR2 FB-DIMM
    GPU ATI Radeon HD 2600 XT 256 MB
    OS X 10.8.2 (12C60)
    Decklink Studio Video Card
    However the testresult are the following:
    Is it not possible to get better performance out of this situation?
    I do get constant frame dropouts when playing material in FCP (7) in 1080p.
    Is the GPU of great importance when it comes to performance in FCP?
    Kind regards,
    Johan
    Johan Windh replied 13 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Juan Salvo
    January 15, 2013 at 11:24 pm
    This app is only testing your disk speed. Want faster performance, get faster drives.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Justin Strauber
    January 16, 2013 at 5:28 am
    Unless you go up to RAID arrays, you’re limited to the speed of your disk, and that looks about right. External SATA with a PCIe RAID card would be your best bet, I think.
  • Glenn Sakatch
    January 16, 2013 at 7:42 pm
    If you want solutions for drive speeds…it might help to tell us what your drive setup is. If internal…stripe a couple/3 of them together and your numbers will increase.
    If esata, than the esata card will have a big influence…cheaper card…cheaper performance.
    Lots of possibilities…just takes time, money, and testing
    Glenn
  • Johan Windh
    January 17, 2013 at 8:52 am
    Thanx for the response guys.
    The drives are:
    320 GB SATA (ST3320820AS_P)
    1 TB SATA (system) (WD1002FAEX-00Z3A0)
    2TB (WD2002FAEX-007BA0)
    2 TB SATA (Hitachi HUA722020ALA330)
    Oh btw, is this the cause to the constant frame-dropouts during playback in FCP?
    Kind Regards,
    Johan
  • Johan Windh
    January 21, 2013 at 9:11 am
    I’m going with a bump here, regarding my last post.
    I’m REALLY appreciative of any help.
    Kind Regards,
    Johan
  • Glenn Sakatch
    January 21, 2013 at 5:20 pm
    So it looks like you basically have two seperate 2tb drives for your main storage…both internal?
    As i said earlier, stripe those toghether and your speed will increase, or start heading down the road of a Raid confing, with a proper Esata card, SAS card, or something along those lines. Individual drives are not really geared towards media recording and playback. As Juan said, those speeds look about right. I’ll bet your speed doubles if you stripe the drives together. Get rid of the 320, add another 2tb and create a 3 drive stipe, and i’ll bet it goes off the chart. Ofcourse in that scenario you have absolutely no
    file protection. A decent Raid 5 config will net you closer to 200 mbs, an expensive Raid card even more.
    Glenn
  • Johan Windh
    January 22, 2013 at 11:49 am
    Thanx Glenn. I’ll have a look at those setups.
    Do you think that this will make the framedrops stop? (Is the disk-issue the cause of the dropped frames?)
    Kind Regards,
    Johan
