Activity Forums VEGAS Pro Is it possible to force Vegas automatically recalculate clip length when using event velocity? Especially for multi-trimmed clips.
  • Is it possible to force Vegas automatically recalculate clip length when using event velocity? Especially for multi-trimmed clips.
    Posted by Ivan Balalayka on December 15, 2014 at 4:11 pm
    Here is my problem:
    for example I have
    1) video track, getted by splitting one video in two parts, where:
    first part – 4x speeded up video (with ctrl-key, up to 4x, or whatever speed I want)
    second part – 1x speed video.
    2) music
    3) speech sound
    and now I have music change and video change and want to synchronize it more precicely:
    You can see markers – 1 for music changing, 2 for video event changing, and I want to synchronize them, so I adding video speed envelope and do it, BUT – here is my problem video not shows me correct “looping point” from this trim position, cause it virtually ends later:
    So it is looping, and I can see this looping point and trim it manually, but, as I said, here is the problem – this looping point is for the end of whole, untrimmed video (well, maybe speeded up to 4x, whatever).
    Now I have to create subclip for my 4x speed up part of video, and of course it looses all speed/pan/crop changes, I have to put it on timeline and again ajust speed, pan/crop for them and then I can change it velocity envelope and this “looping” point will change correctly.
    So – is any method to do this more easy:
    1) Any
    hard trim, so Vegas did not “remember”, that this clip is longer, than it now, and I would not have to redo all changes for sublip, as I have to do now.
    2) Any method to not only disable loop and also not just getting “freeze” frame if loop disabled, but change clip length automatically? From the trim position, that would be best.
    P.S.: maybe such thing makable in adobe premiere, if so – I can do it there, but as I know, it even have not options to automatically move “looping point” for speed envelope at time it moving, only after moving, and this bad 🙁
    John Rofrano replied 11 years, 8 months ago 2 Members · 5 Replies
  • John Rofrano
    December 16, 2014 at 6:09 pm
    [Ivan Balalayka] “1) Any hard trim, so Vegas did not “remember”, that this clip is longer, than it now, and I would not have to redo all changes for sublip, as I have to do now.”
    That’s what a SubClip is. You used it correctly. SubClips are for times when you want a longer video to behave like a shorter one with the correct looping.
    [Ivan Balalayka] “2) Any method to not only disable loop and also not just getting “freeze” frame if loop disabled, but change clip length automatically? From the trim position, that would be best.”
    Unfortunately no. You must manually change the length when you apply a velocity envelope.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ivan Balalayka
    December 16, 2014 at 7:10 pm
    Maybe it is possible to trim somehow in subclips, so they were already on timeline without have to move them to timeline from media explorer?
    or, it looks like I need some vegas script like:
    1) copy event attributes from selected original event
    2) create subclip from original event
    3) delete original event
    4) paste subclip at place of original event
    5) paste event attributes
    6) change subclip length accordingly to original event
    7) delete grouped autiotrack if it was deleted for original event
    Maybe some sort of such script already written or some script-bunch have it/part of this algorithm?
  • John Rofrano
    December 18, 2014 at 5:57 pm
    [Ivan Balalayka] “Maybe some sort of such script already written or some script-bunch have it/part of this algorithm?”
    You could just right-click on the original event and select Create SubClip and it will turn the event into a trimmed subclip with all of it’s attributes intact. 😉
    ~jr
  • Ivan Balalayka
    January 10, 2015 at 3:10 pm
    Wow! Thank you. When I did this before I saw created sublip in Project Media and thought it just creating subclip, but instead this option replaces current event with subclip and saves every event attributes!
  • John Rofrano
    January 10, 2015 at 3:22 pm
    [Ivan Balalayka] “…but instead this option replaces current event with subclip and saves every event attributes!”
    Yea, it’s a really useful feature. Glad it helped.
    ~jr
