Activity Forums Adobe After Effects Is it possible to embed images in ScriptGUI by using the ressource string method?
  • Is it possible to embed images in ScriptGUI by using the ressource string method?
    Posted by Adirai Maji on December 23, 2019 at 11:54 am
    Dear script developers,
    I’m trying to embed graphics in my UI. I would like to make Dockable GUI. To build the UI, I use the ressource string method. But I still can’t figure how to embed graphics in the layout.
    Here is what I’ve tried:
    function myScript(thisObj) {
    function myScript_buildUI(thisObj) {
    var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", "My Panel Name", [0, 0, 300, 300]);
    var myIcon = "\u0089PNG\r\n\x1A\n\x00 etc etc"; //this is where I paste the image data
    res="group{orientation:'row', alignment:['left', 'top'], alignChildren:['center', 'center'],\
    myPanel1: Panel{text:'Panel1 Name', orientation:'column', alignChildren:['center', 'center'],\
    myPanelItem1: IconButton{image:'"+myIcon+"'},\
    myPanel.grp = myPanel.add(res);
    myPanel.grp.myPanel1.myPanelItem1.onClick = function(){alert('yo')};
    myPanel.layout.layout(true);
    myPanel.grp.minimumSize = myPanel.grp.size;
    myPanel.layout.resize();
    myPanel.onResizing = myPanel.onResize = function () {this.layout.resize();}
    return myPanel;
    var myScriptPal = myScript_buildUI(thisObj);
    if ((myScriptPal != null) && (myScriptPal instanceof Window)) {
    myScriptPal.center();
    myScriptPal.show();
    myScript(this);
    Is there a way to make this works or should I forget about the ressource string method to put images in my GUI?
    Thanks in Advance…
    – Adirai Maji
    Adirai Maji replied 6 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
