Activity Forums Adobe After Effects Is it possible to “decompose” a composition?
  • Is it possible to “decompose” a composition?
    Posted by Daniel Haskett on May 24, 2005 at 11:07 pm
    Hi there
    Ive looked in the help menu but cant find anything under decompose..so i just thought id ask here. Basically if you precompose a few layers but then decide you want to change the timing of a couple you need to decompose the layer right? Or something to that effect, whats the best way of editing precomposed layers in a composition?
    Dan
    Jochem Smit replied 15 years, 8 months ago 4 Members · 3 Replies
  • Jeff O’brien
    May 24, 2005 at 11:24 pm
    Well, what I do is option-double click on the pre-comp in the timeline, this opens it up so you can work in it. If you have “Syncronize Time of All Related Items” checked in the General section of the Preferences, this will make it easier to see what you’ve done in the original. Also, if you have enough monitor real estate, you can separate the windows and timelines for the pre and the main to help see the end result.
    FWIW,
    Jeff O’Brien
    Windward Visual
    Lake Oswego, OR
  • Filip Vandueren
    May 24, 2005 at 11:47 pm
    You can copy-paste all the layers from the pre-comp to the main comp.
    Make the precomp layer invisible.
    then parent the layers to your precomp-layer, so they inheret all the motion keyframes from it.
    But if you’ve blurred the precomp or added another effect to the precomp
  • Jochem Smit
    December 16, 2010 at 2:57 pm
    I want to animate (position) a single layer in a precomposed (AND DUPLICATED) composition in AE. If i do so it apllies to all layers in the precomposition and EVEN to the layers in the original composition it had been duplicated from. The same happens when I try to rename a layer…
    Anyone an idea how to de-root those connection and make the layers “independent of eacht other and original” ??
