Is it possible to create random rotation in AE that then stops when it hits a floor?
Hey,
Basically, Ive got a layer that im using as the particle for particular. It falls from the screen to the bottom and bounces off the floor and rests. There are then multiples of this created by particular that do the same. What i basically want to do is make it a bit more random, however the rotate function in AE rotates all the layers the same amount….
I rotate the layer in its separate comp, but then there is no way to stop it rotating when it hits the floor….
Hopefully this makes some sense! Basically i need each particle to rotate at different times and then stop when they hit the floor….
Any tips would be greatly appreciated!
Cheers
Dan
