Activity › Forums › Adobe After Effects › Is it possible to create position/rotation/scale presets in After Effects ?
  • Is it possible to create position/rotation/scale presets in After Effects ?
    Posted by Max Mahowny on November 26, 2012 at 1:43 pm
    Hey,
    at the moment i have to deal with about 50-100 shots per day,
    all shot in 1280×720, wich i have to rotate,scale & position exactly the same way & each clip needs to have its own sequence.
    I was wondering, if there is any possibility to create an effect,
    wich automaticly places the layers in the right way. So i don’t have to do it all by hand.
    position : 178,0,74
    scale : 35,0
    rotate: -90,0°
    Thank you very much in advance !
    Vishesh Arora replied 13 years, 9 months ago 3 Members · 2 Replies
  • John Cuevas
    November 26, 2012 at 3:44 pm
    You need to make an animation preset. Create your position,scale and rotation for one layer. Press UU quickly to open up the changed properties for the layer and select them all. Now just go to the menu bar Animation > Save Animation Preset and give it a name and save it.
    It should appear in your Effects & Presets window under the user presets. I don’t do scripting, but if someone came up with script or macro to automatically apply that preset to your layers, you’d be all set.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Vishesh Arora
    November 26, 2012 at 4:10 pm
    Max
    Apply Transform Effect(Distort>Transform) to a solid and change the transform properties in Effects Control Panel.
    Now go to Animation> Save Animation Preset and save it at Adobe After Effect Preset Folder.
    Now apply it to you Layers and it will automatically apply the transform properties that you have saved as a preset.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
