Activity Forums Adobe After Effects Is it possible to create and animate shapes WITHOUT anti-aliasing?
  • Is it possible to create and animate shapes WITHOUT anti-aliasing?
    Posted by Matt Chandronait on June 15, 2012 at 12:09 am
    Just trying to save myself some time while animating some pixel art. Anyway I can create shape layers and somehow “turn off” the anti-aliasing?
    Matt Chandronait replied 14 years, 2 months ago 2 Members · 4 Replies
  • John Cuevas
    June 15, 2012 at 2:43 am
    Toggle the quality switch to “Draft” Its the diagonal line in the Switches column.
    Link
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Matt Chandronait
    June 15, 2012 at 4:05 pm
    Tried that :). It works in the timeline, but in the final render everything is still nice n’ crispy as I think the quality switch is just to speed up things in the timeline. I need, of course, a way to render things out without anti-aliasing as well. But thank you for the response!
  • John Cuevas
    June 15, 2012 at 6:23 pm
    Are you rendering to Best quality, cause you would need to render the graphic at “Current”
    Another way to do it would be to just add a mosaic effect to your graphic and set the blocks to 1/2 to 1/4 of your current resolution.
    Thinkck.com
  • Matt Chandronait
    June 15, 2012 at 9:42 pm
    Ah! Fantastic tips! Thank you so much man 🙂
