Activity › Forums › Apple Final Cut Pro Legacy › Is it possible to create a discreet audio data disc in FCP?
  • Is it possible to create a discreet audio data disc in FCP?
    Posted by Dan Herz on May 10, 2009 at 6:31 pm
    I am working on a project that needs to be delivered to TV Stations for broadcast. It is a 3 minute package that includes voiceover, BG audio, music & SOT’s. I would like to deliver on a DVD, but need the audio to be discreet so the music or voiceover can be removed or replaced.
    The project is XDCAM HD with some other files/formats included that I have converted to XDCAM HD. Is it possible to create a data disc and keep the audio discreet? any suggestions on how to do this…or possibly another solution?
    One other note…I have a Sony Z-7 HDV camera…so as a last resort, if the data disc does not work, could I convert the XDCAM HD project to HDV project and print to tape on my camera?
    Dan Herz replied 17 years, 4 months ago 2 Members · 3 Replies
  • Andy Mees
    May 11, 2009 at 12:18 am
    Dan
    Just set your sequence audio outputs to the appropriate number of dual mono audio pairs, then assign your timeline audio tracks to those outputs accordingly. Export your Quicktime Movie w/Current Settings and you’ll have a Quicktime Movie file with multiple discreet audio tracks as defined by your FCP sequence audio outputs. Note: Don’t be misled when playing this back in Quicktime Player which will automatically mix all audio tracks to 2 channels, although it plays back in Quicktime Player in this fashion the file itself contains true discreet multiple channel audio which will be properly recognized by any multichannel aware/capable Quicktime app.
    Setting Audio Outputs
    In FCP, go to Sequence Settings window >> Audio Outputs tab and set the number and type of outputs desired eg 4 channel, Dual Mono, Dual Mono would be sufficient for Ch1: VO, Ch2: SOT’s, Ch3: M&E, Ch4: Music
    Assigning Sequence Audio to Outputs
    In the timeline, right click on or around each audio track’s Autoselect or Track Lock icon and from the context menu choose Audio Output and select the desired output channel for that track (you can also do this track assignment directly in the Audio Mixer Tool window by right-clicking on each track’s number in the Tracks pane at far left)
    Hope it helps
    Andy
  • Dan Herz
    May 11, 2009 at 2:13 am
    This is great info! Thanks for your help, Andy. I will give it a try and see if I can figure it out. Much appreciated.
    Dan
  • Dan Herz
    May 17, 2009 at 11:37 pm
    I fnally got around to testing this out and I am a little confused. When I changed my audio output settings in FCP, a dialogue window came up saying the following:
    “the current audio device does not support the number of outputs set in the sequence settings audio output tab. Unsupported outputs will not be heard during playback on this machine unless downmixed to stereo”
    Then it gives options to downmix all outputs to stereo.
    Also…I followed your directions and was unsure what to do once I had set outputs in FCP and on timeline. do I export using Quicktime conversion and then drop the file onto the DVD icon to burn the data disc? Sorry if this is basic stuff…I do not have much experience with this.
