Activity › Forums › Adobe After Effects Expressions › Is it possible to convert slider decimal place to FPS?
  • Is it possible to convert slider decimal place to FPS?
    Posted by Ronan De lacy on May 19, 2021 at 7:55 am
    Hello forum.
    Does anyone know if it’s possible to change the decimal point range of a slider control from 0-99 to 0-FPS of the comp? For example if my Comp frame rate is set to 30 and I have a slider applied an effect to a value and I want that effect to occur at 1 second 15 frames, default the slider will read 1.50, but I would like it to read 1.15.
    Thanks in advance for any input.
    R
    Ronan De lacy replied 5 years, 4 months ago 2 Members · 2 Replies
  • Filip Vandueren
    May 19, 2021 at 11:40 am
    t=effect("time")("Slider").value;
    frameRateOrderOfMagnitude = Math.pow(10,-Math.floor(Math.log10(thisComp.frameDuration)));
    secs = Math.trunc(t);
    frames = timeToFrames(t-secs);
    output = secs+(frames/frameRateOrderOfMagnitude);
  • Ronan De lacy
    May 20, 2021 at 7:36 am
    Thank you, Filip! This is just what I wanted to achieve!
