Forums › Adobe Illustrator › Is it possible to change the program font?
Phil Radelat
December 16, 2010 at 4:36 pmIs there any way to change the font used in the new CS5 suite? Ever since CS4, Adobe has been using a type style that just uses up more real estate. They use a thicker font because they’ve defaulted to a badly thought-out color scheme that will render the text unreadable otherwise. This forces you to use a wider box for your palettes.
Notice the type here in CS3:
https://i75.photobucket.com/albums/i312/vidrazor/gudtype.jpg
and now look at it here in CS4/5:
https://i75.photobucket.com/albums/i312/vidrazor/badtype.jpg
Notice how the type gets cut off.I would love to get the type style back to the CS3 format if possible, thanks.
les nemeth
December 16, 2010 at 6:56 pmThat’s the best I can recommend.
Phil Radelat
December 16, 2010 at 8:14 pmI’ll take that as a “no”, LOL!
Log in to reply.
